Http://www.copytechnet.com/forums/kyocera-mita-copystar/20557-kyocera-km-4035-system-error-c2500.html
https://printcopy.info/?l=en&mod=erc&brand=Kyocera&model=KM4035&code=C2500
Kyocera KM4035 Error Codes
Exploded Views and Parts List Free!
Code
C2500
Description
Paper feed motor problem • LOCK ALM signal remains high for 1 s, 1 s after the paper feed motor has turned on.
Causes
Poor contact in the paper feed motor connector terminals. Defective paper feed motor rotation control circuit. Defective drive transmission system.
Remedy
Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper feed motor. Check if the rollers and gears rotate smoothly. If not, grease the bushings and gears. Check for broken gears and replace if any.
SOURCE: error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and ....my comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). .........secure replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
SOURCE: Triumph-Adler 4035 Firmware
latest firmware for FS-3900DN:
system: 2F9_3000010.004 checksum:5204 version:010.004
engine: S2F9_1000011001 checksum:f7bf version: 011.001
I don't think the problem is in the firmware ...
SOURCE: Error Code C2500 on a Kyocera KM-2530
a C2500 error code relates to the paper feed area.
It indicates either a faulty paper feed motor, loose plug for the motor or lubrication problem in the feed area.
Hope this helps.
SOURCE: how do I make my kyocera mita 4035 printer print w...
change paper size from printer properties maybe the paper size is LTR so you have to change it to A4
