SOURCE: denon 3801.cant display setup on tv
Hello gerrydav,
What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it.
I look forward to your posts.
SOURCE: Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
SOURCE: I have a Denon AVR
The optical audio connection (the TOSLINK) only works when paired with the Component connectors. Now you are using the the Composite one so you must use the audio connectors associated with it, the red and white next to it; then select the VCR1 input when you want to use them.
The audio quality will suffer a little but it will most surely pass unnoticed in most of the cases.
