SOURCE: Upgrade Ubuntu Error
-While booting your grub bootloader, press "e", enter the edit mode.
-Press "e" on the first line.
-(hd0,0) Change the last 0 to a 2, so it reads: (hd0,2).
-Press ‘b’ to boot.
Good luck.
SOURCE: Hi I have Sony VAIO
This means that the operating systems was not installed properly...."Boot manager is failed... and ntldr is the main file... which help computer to boot up..." try reinstalling the operating system again...
SOURCE: Nokia 7210 supernova Security Code error
hi I have bought 7210 supernova is it possible to change fro S40 5th edition package 1 to S60 3rd edition, as i have many software of the later
SOURCE: Hi! My LG washing machine is
Hi, the error code "dE" signifies a door open error. This may simply be because the door is not all the way closed. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
SOURCE: LG WM3677HW - error code OE. During drying cycle,
Check the filter at the bottom left side of the washer. It could be plugged up with debris.
Hope this helps.
