Dryers Logo
Tamm Chong Posted on Aug 06, 2018
Model HLF103Q. How can I remove drum? - Haier Dryers
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
tip
Drum needs to be replaced message,Remove waste toner,Waste toner full
Save money by removing your drum units waste toner yourself.By removing waste toner the drum life will be increased.Remove the waste toner every 3 to 5 thousand prints.
The main cause of drum failure in this model is caused by waste toner build up at the back of the drum,this cause the drum cleaning blade to put more pressure on the drum and.
Slide the platte-ned cover Assembly to the left open the left cover,remove the drum and developing Assembly like you do when you have to remove a paper jam.The drum and developer assy is attached by 2 blue clips,unlock the clips and separate the def and drum.On top of the drum unit the is a plastic plug that you can remove and trough out the toner in a dustbin with plastic bag coverd.Do not use this toner again in the machine.
Reinstall the plug and connect the drum and developer unit with the two clips.Reinstall the unit.
By removing the waste toner regally you will save on service cost as well.
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Haier dryer will not turn off
It's dangerous and faulty ..........
Recyle it and treat yourself to a safe new product.
You know it makes sence
How do I change the drum in my HL-5240
First check whether it is possible to buy a new drum for your model, if possible buy a new drum then remove the toner from your printer, separate the drum unit from the toner, if you check thoroughly the left and right sides of the drum unit how the drum has been fixed in to it you will be able to find the way remove drum from the unit, then replace the new drum and fix it. Don not tough the edge wiper blade, rotate the drum and check whether it rotating smoothly in both direction.
No heat and motor won't turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
I have this dryer and ican here the motor hum but
Check the belt for it may have come off or broke. The top must be removed to see
3helpful
2answers
Cracked drum on the DLE3777W model
The drum is a part number 3045EL1002F which will set you back at least $135. Still well worth the repair, especially if you can install it yourself. You have to remove the top by removing 3 screws in back and sliding top back about 2 inches and lifting off. Then, remove front panel. Remove 4 screws holding the front bulkhead. Remove belt from drum. Remove drum. First time might take a hour, second one you do will take about 15 minutes.
Now, don't rate me down because you don't like having to repair your dryer. I didn't manufacture it. I'm just giving you a bunch of free advise.
2helpful
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Top Haier Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a Haier Dryer Expert? Answer questions, earn points and help others
