SOURCE: Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
SOURCE: Zanussi Tumble Dryer Model TC7103W ** Heat
have u changed the thermostats if not change these these r what let the heater element get warm if this then works then the element u changed will more then likely be OK m8
SOURCE: how to fix a belt on zanussi tumble dryer model number zdc 46130s
heat elemet works, drum will not tumble. Help. Little odl aldy, Rosemarie
SOURCE: how to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door
seal:
For all Free appliance repair videos visit our VIDEO
TUTORIALS
Disconnect all power to the machine first!!
1 Locate the
outer clamp band securing the seal to the door rim on the washing machine and
examine it carefully for holes or tears. Many can be prised off with a
flat-bladed screwdriver they have a spring system holding them, but some have a
tensioning arrangement that has to be loosened.
2 After
removing the outer
clamp band, locate the inner one securing the seal to the drum and
establish how this is secured. It may be necessary to loosen a clip, or you may
be able to prise the band off with a flat-bladed screwdriver. Some are like
very large Jubilee clips that you have to undo usually from the top.
3 Once the
clamp bands have been removed, use both hands to pull the seal away from the
inner drum rim. Some machines have a water spout holes that will have to be lined
up. Others have a drain holes.
4 Rubbing a
drop of washing up liquid into the groove on the door
seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing
machine door seal should be fitted by locating the drain holes at the bottom
of the seal first then push it on with both hands working opposite directions
towards the top. This is quite hard if you have never done it before.
6 refit the
inner band remembering this must be tensioned correctly for it to be water
tight.
7 now fit the
outer band and the test the machine for any leaks,
All washing machine spares featured in this article are
available at apart4u with more video
help in our tutorial
section.
Information provided is a guide only. aPart4u accepts no liability for any
problems occurring whilst attempting any advice shown. If in any doubt about
fixing your appliance, always contact a qualified repairer.
SOURCE: fit felt drum seal to zanussi td4212 w tumble dryer
I
take it that the belt is ok and the drum is turning.The heater comes
with thermostats fitted as a complete part.There is an overload safety
thermostat which is situated inside the drum and above the door,it is
held in place with a self tapping screw then prise open the plastic
cover and then the thermostat will pull out,if replacing remember to
refit the small gasket.Have you checked the filters and exhaust hose for
any blockages as this will affect the heating.
Hope this helps
