SOURCE: sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
SOURCE: aVLS MODE
Hold the sound button for a few seconds (the button that boosts the bass depending on which model walkman)!!!! That should do it.....
SOURCE: sony cd walkman D-EJ100 troubleshooting
There is a switch on the bottom of the unit that puts it in "HOLD" mode. My guess its for use when it is shipped so there will be less chance of damage. Try switching the two position switch to the other position.
SOURCE: sony walkman won't turn off
That's what all Walkmans do. They only seem to go into standby when they say power off. Batteries drain anyway, but maybe it is being switched back on accidentally, so you need to turn the hold switch on. Even then, it is not properly switched off, it just stops things happening like music starting to play. I find this very annoying too.
