SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure.
This sensor is used to know water level in the tube. It is probable
that your model reports the same codes.
It does not necessary means
a broken sensor you must check the electrical connectors and cables as
well as all the mechanic and pneumatic elements like the hose connected
to the sensor.
It is often clogs with soap and other particles.
Good Luck!
SOURCE: Water overflowing during use
Seems like blockage in pressure system, machine will always think it is empty if so. Pressure system is under the lid, a round switch with a thin pipe going to it. At bottom of this pipe it is probably blocked with limescale or residue from detergent.
SOURCE: a pure korean made Daewoo
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
This is likely to give you only a user manual which normally will not contain such details as electrical diagrams. The manufacturers will normally only supply those to their service engineers.
You comment 'we need a manual and electrical diagram that translate in english' makes me think you already have the electrical diagram albeit in Korean?!! You could try a Daewoo site direct.
Hope this helps and good luck,
John C
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
SOURCE: daewoo washing maching model dwf-760mp
daewoo washing maching model dwf-760mp nano silver, when i press start water comming out continously
