SOURCE: motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
SOURCE: kenmore dryer- remove fan to change motor on
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Just bought a Maytag 3000 washer and dryer and
Most likely the metal is aluminum or stainless and you should worry about rust unless you wash your clothes with salt-water (seawater. not gonna happen.)
If you're really concerned, I'd attempt to reach a maytag customer service person.
800-462-9824
To reach a real person press 0 at every option. Should take three times.
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
SOURCE: i have my kenmore 80 series dryer apart, and i am
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
