SOURCE: Fisher and Paykel Washer leaking water
call fisher paykel they will take care of you chances are the diverter valve is bad they have been having problems with them and make sure your repair people are fisher paykel certified VERY IMPORTANT
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
SOURCE: washer will not drain
90% chance that is the pump is pumping water at all, there is blockage between the tub and the drain pump. If there is no water coming out of the drain line. either extremely clogged(odd) or pump motor is bad, and windings are not allowing rotation.
SOURCE: Too many suds
Error #37 is a pump blocked error. Says that machine has not drained out. Check that the pump is not blocked (by removing the top, agitator and basket) or that the drain outlet is not too high. ( maximum height for drain outlet is 7'). If you do end up throwing the thing out, I'll give you something for the motor controller circuit board as I think mine is faulty.
