SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
SOURCE: DS6708 symbol scanner freezes keyboard
Have you tried taking the battery out of the scanner and then reinserting it? THis should reset the scanner to some degree.
It really depends which barcodes you scanned in the manual.
Your best chance seems to be a reset to the original settings, for which you may need to look at the manual.
SOURCE: how to enable barcode scanning with C#
Have you tried DataWedge from Symbol. It allow the barcode scanner to interact with standard applications
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
First:
a) Do you have the scanner connected to an Y cable ?
If yes, you need to connect to the PS/2 port on the computer and you have to connect another 101 keys keyboard
/ PS/2 computer port
scanner ----
\ 101 keys keyboard.
restart the computer and will work.
the system will include the driver in the keyboards.
Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
b) if you do not have the Y cable:
just install the driver : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Good Luck
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
