Question about Juki Sewing Machines
Timing a juki ddl 555 and how to set needle bar
    Novelist:
    Scholar:
  • Juki Expert
  • 90 Answers
  1. I am surprised that you have to set the needle bar but put a NEW needle in the bar or make sure that the needle set screw is to the right side of the bar
  2. If your needle bar is already loose, there should be two small lines about 1/4" apart on your needle bar, where you can see it between the needle and the underneath of the machine.
  3. The needle bar height is set when the top line is flush with the body of the machine. Tighten your needle bar screw.
  4. Now wind the hand wheel towards you until the 2nd line is flush with the body of the machine. Push your machine back so you can see the hook. Set the tip of the hook one thread away from the scarf of your new needle and in the middle of the needle. Tighten the screws on the hook, put the machine back down (make sure that you have put your bobbin case back in) and test to see if you can pick up a thread when you wind your hand wheel towards you.
  5. If you are not picking up the thread, I find that I have to put my throat plate back on to pick it up most of the time.You may have to redo this several times especially if your hook is old and worn. It's possible but harder.
  6. Good Luck. There are a couple people on youtube showing how to time a sewing machine. They are all pretty much the same. It doesn't have to be someone who is especially trying to time a 555,
Posted on Dec 02, 2018
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Needle not catching thread
im no expert, just been sewing for many years, i use 2 different juki machines, i suggest looking at the needle, are we sure you have the rite size? 135/ 140? did the needle just get changed? it could be the correct one, but if its in backwards, there isn't a dimple to let the hook behind the thread, to catch it, feel free to call me, 239-895-4845, my name is devin, shop is Quality Auto Trim Inc., ill try to help you over the phone if necessary, good luck
Posted on Mar 12, 2010
paj42
  • 1116 Answers
SOURCE: What needle type is used for the juki ddl 555?
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
Posted on Mar 18, 2010
cup00
I use Organ needle in mine. You can find these at most dealer who carry industrial parts, including ebay.
Posted on Sep 23, 2010
SOURCE: how to set timing and bobbin in my juki ddl-555
hi there
when you need to set timing please first make sure height of needle bar is ok. there's two mark at needle bar, the upper one is for height of needle bar: bring the needle bar at lowest position and in this case the upper mark must be equal with lower needle bar bushing.
second : set timing
move hand machine pulley at the same rotation and when the lower mark equal with lower needle bar pushing the tip of hook must be at the center of needle groove and just light touch not hit. that's all
best regards
ashraf abozid
CAIRO - EGYPT
Posted on Dec 17, 2012
Hi I just purchased a used Juki DDL-555. 1) It will not catch the bobbin thread. 2) it will not sew forward and feed the fabric along (it sews in reverse just fine). Can someone please help?
the material movement is set by the forward/ reverse knob or lever
not picking up the thread can be needle thread tension too loose
it can be needle hook timing
Apr 20, 2017 | Juki Sewing Machines
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
How to set timing and bobbin in my juki ddl-555
hi there
second : set timing
best regards
ashraf abozid
CAIRO - EGYPT
Nov 29, 2012 | Sewing Machines
May 11, 2010 | Juki DDL-8300
Mar 18, 2010 | Juki DDL-8300
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
Juki stuck needle
check settings
Apr 28, 2008 | Juki DDL-8700
Sewing Machines Logo
209 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
