How to remove chain drive on makita Dcs6401-20?
HI , FIRST UNDO BOTH SIDE COVER BOLTS ON THE CHAIN COVER AFTER MAKING SURE THE CHAINBRAKE IS IN THE OFF POSITION,[BRAKE LEVER PULLED BACK].TAKE THE TWO NUTS OFF REMOVE THE COVER,LIFT THE BAR SLIGHTLY AND PUSH IT TO THE REAR.THAT WILL LOOSEN THE CHAIN SLIP THE CHAIN OFF THE BAR AND REMOVE THE BAR ,ONCE THE BAR IS OUT OF THE WAY ,YOU TAKE THE CHAIN OFF THE SPROCKET BEHIND THE CENTRIFICAL CLUTCH AND SLIP IT OUT AROUND THE BACK. AFTER CLEANING EVERY THING ,PUT IT ALL BACK THE SAME WAY .YOU WILL HAVE TO SCREW THE ADJUSTER BACKIN SO AS TO EASILY FIT THE BAR TO THE ADJUSTER PIN ,IT IS NOT DIFFICULT AND AS YOU SEE THE PARTS IT WILL FALL INTO PLACE
