Clothing Accessories Logo
A
Ajay Mahanta Posted on Aug 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lumious invertor no load shoeing kindly solve it
OHare
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 78 Answers
  • Posted on Jan 30, 2019
 OHare
Expert
Level 2:
Cheetah:
Answers
78
Questions
0
Helped
28751
Points
129
What is the exact problem?
I bought a bag and shoes set but need bigger shoes do i have to send both back and reorder or just send back the shoes
Who is the person u bought the shoes from? See what kind of return policy they have and contact then about the wrong size ??. You only have to return the shoes
I have one shoe need to be repair and I dont have the shoe discreption and ref# number kindly I need your help
Usually both shoes need to be fixed and it is a good idea to take them to a shoe repair shop and have them help you with the problem you have.
1helpful
2answers
I already enter password for my facebook but they nothing inside it being block chome by some want i dont know how to solve this problem?i want my facebook back to open.
if google chrome isn't allowing you to access your Facebook try using a different browser like firefox, or internet explorer.
hope this helps!
1helpful
The LCD has sound, receive all chanels, but no picture. The screen is black.
Hallo! Your problem is in the invertor block. Caution! High voltage! approx. 1500V at the exit to the lamps. The possible reasons: 1. the voltage doesn't arrive at the invertor board. In this case check the voltage at the enter of inverter board. Many times there is a little green fuse that burns. 2. when you switch on the TV, if the screen blinks for one- two seconds, this may be problem with the high voltage transformator, to replace 3. the lamps. only to replace with other for checking 4. the board of the invertor. In this case, take the schematics, make the measures and post them, we will try to solve it.
1helpful
I turn on my samsung syncmaster710 and it just has a black screen, with a faint (very faint box floating around it. is this a fualty backlight?
The backlight invertor seems to be defective.
Check the main power supply board for bad capacitors (visible damage ) and make sure that the invertor tubes do not light up for a moment when you power up the monitor ( in that case their probably is one or more light tube defective (burnt)) --
My skytronic power invertor is making a constant beeping noise
do you have a load plug in at the time if so try it with nothing plugged in if all is fine the load may be to big for the invertor
Frigidaire (glws1439fs1) top load washer
If your machine is old means may be brake shoe might be very closes joined make adjustment and correct it otherwise it is a bearing noise kindly replace the bearing along with washer
11helpful
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Fuji Invertor FRN18
Based on your post, the local distributor of the AJAX CNC Lathe can not repair nor replace, then perhaps you should try to go direct to the systems manufacturer.
  • Fuji Electric Co., Ltd.
  • ED & C and Drive Systems Group
  • 12-1 Yurakucho 1-chome, Chiyoda-ku Tokyo, 100-8410 Japan
  • ED & C Phone 3-3211-1424 Fax 3-3211-7983
  • Drive Systems Phone 3-3211-1425 Fax 3-3211-7982
  • Fuji USA;
Alternately, you could try a local Industrial Electronics Tech. who is familiar with these and has access to a service manual or at least a schematic diagram.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 • Drills
Top Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
john h
Don A
Don A
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
