tagi heidarzad Posted on Aug 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have this error " problem prevented the document from being scanned with kodak 2600" please help me
chris bauer
Level 2:
Habit-Forming:
  • Expert 135 Answers
  • Posted on Aug 16, 2018
chris bauer
Expert
Level 2:
Habit-Forming:
Answers
135
Questions
13
Helped
26672
Points
422
Please specify the error code, number like E720 or similar
2 Related Answers
Robert McGinley
  • 21 Answers
  • Posted on Jan 08, 2011
SOURCE: when trying to scan from
try reloading the drivers and software for the printer
Anonymous
  • 910 Answers
  • Posted on Jul 19, 2012
SOURCE: kodak i660 black line on scanned document
The black lines are caused by either marks on the scanning strip or a fault with the scanner. If there are no marks on the scanning strip then there's nothing that can be done without sending it for repair. Details of the cleaning procedure are shown in the instruction manual.
1helpful
I have kodak i2600 scanner, when i was scanned document its getting black lines on the document how to solve this problem please help me
Black lines on most any scanner will be caused by dirt in the scanning system, or by a damaged/defective scanner sensor. You can clean the window.
Kodak error alert accompanied by a 4 digit number. I just filled out a multiple sentence question on your Fixya 295 space. Did you get it???
You must be more specific with the "Kodak error alert". What was contained in this alert? Was there an error code associate with this alert? What 4 digit number accompanied this error? And what type of software were you using to scan when this error occurred?
3helpful
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
3helpful
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
When opening the kodak home center got an error.
it is a scanning error............ scanning usually take 1-2 minutes to scana document. make sure dat u've proper ink in ur cartridges. contact kodak@ 1800 21 6699 for further issues.
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
2answers
My kodak easy share 5300 all in one printer will not scan
are getting any error msg like 1-2036 or anyother and are you using Vista or Xp,,,,try using the windows fax and scan settings....let me know and i will try and help you
Cannot scan with my kodak easyshare multi funtion 5300
please help me how to solve my problem..
i dont know how to transfer my picture from my didgital camera to my document ..
and i dnt know how to preview and share my pictures...
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
