SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
SOURCE: Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
SOURCE: My ricoh sp c811dn suddenly started displaying the
Here is a way to reset but make sure you follow the instructions correctly.
turn off machine
press online and escape buttons together whilst turning on machine,
when display comes up wait till three options are listed, use arrow button down to select engine, use arrow right to select mode(5.mode) and ok, left arrow to 5.810 SC RESET. OK. PRESS OK AGAIN AND THEN EXECUTE AT BOTTOM OF SCREEN.
Turn off printer and wait ten secs then turn back on.
If only temp error this should reset and start up again, Good luck
SOURCE: wat i can do with my printer ricoh aficio sp c420 dn
Good afternoon Omar, my name is steve.
This error code can relate to one or two things.
1. PCU Photo-Conductive Unit is bad or needs to be replaced.
2. A defective High Voltage power supply board.
If it has not been serviced in awhile,and no user supplies other than toner has been installed in it, I would consider the first option.
I hope this assists you, best regards,Steve
