55 inch 4K Westinghouse WD55UX4530 I took off the back panel and I found that everything looks okay or so I think. I took pictures too. I can see the images moving but are very dim. The flashlight test didn't really show me anything
Your backlights have failed, taking it to a repair shop for service will run between 150 and 200 dollars, you can replace the LED strips yourself but its not an easy job if you haven't did it before, its very easy to damage the panel when taking it apart and putting it back together then the money spent on the strips is wasted and the TV will need to be recycled...Good luck!
SOURCE: Power up okay with logo screen, and after takening picture no picture on screen
Canon technical support is the place to go. There has been a recall with some camera because of a faulty CCD This may be one of them - check it out.
SOURCE: TV turns on, sound is
Classic case of faulty LCD controller(T-CON) board. Replacing it should resolve the problem. Please get me the make and model number of the set so that I can find you a replacement.
SOURCE: power on,but no image westinghouse vr-4625any fix?
If there is sound output to all channels, and oly picture is absent, the backlight inverter board should be suspected.
In most of the case, the LED back lights strip is out.
