SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
SOURCE: need code for ge universal remote for dynex 26
Try these codes for dynex televisions. Dynex Television 1023, 1107, 1122, 1273, 1382, 1383, 1384 If these codes do not work you can call the Dynex customer support at this telephone number 1-800-305-2204. Give them the model number of you television and ask them how to get the code. I hope this information helps you with your problem.
SOURCE: progamming code for DYNEX t.v. w/ brighthouse cable remote
Do what I did...
Turn on TV
Press TV on the remote(will blink once)
Press and hold setup until tv button blinks twice
Hit 991 tv key will blink twice
Aim remote at tv press power button once
Press the Chan + key over and over until tv shuts off.
Same instructions as the manual
SOURCE: i need a code for dynex tv to work with directv remote
I tried 10463 and it worked
Dynex is a brand from Sansui made especially for Best Buy......hope it works for you also!!
