SOURCE: feed dog switch
Did you turn the handwheel? The feed teeth will not come up until the machine is operated. Run it a few stitches and they will come up.
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
SOURCE: janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
SOURCE: janome memory craft 7500
the machine comes on , its on auto but the foot pedal does not make contact.
