Unfortunately, the EWR20V5 does not handle DVD +R or DVD +RW discs for recording. It can play back some of these discs, when recorded and finalized on another recording device. However, it may not recognize some DVD +R/+RW discs at all. This recorder recognizes all DVD -R/-RW discs. This is a common manufacturing design for DVD/VCR recorders.
See the first page of the Quick Guide for the EWR20V5 for the disc limitations: https://www.manualslib.com/manual/46971/Emerson-Ewr20v5.html . I hope this helps.
Testimonial: "Thanks for your help. Where can I buy DVD-R/-RW ? Not available locally."
I've usually found DVD-R at Walmart, Staples, and Office Depot. These are both in the stores and online. Amazon also carries the DVD-R and DVD-RW discs. For Staples.com, seehttps://www.staples.com/Blank-Media/cat_... . Searching Google for DVD-R media gives me a long list. Just choose the quantity of discs per package; you may want to check the manual for the EWR20V5 for their recommended manufacturers. (My Zenith VCR/DVD recorder manual recommended select brands of DVD-R discs. I haven't had a problem with those brands with the old device.)
I hope this helps. However, I'm in the U.S.; that may be a factor in the local inventory.
Try burning your DVD using some other DVD burning programs, the discs burned by these programs should work on most devices
How to Convert and Burn MKV to Blu ray with Subtitle
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
SOURCE: disc error
I have this same problem so I called Sharp. This model is a little older. When you buy the disks there is a number with an X after it. If you buy the - R disk the number has to be 4X or less, for the -RW it has to 2X or less. Apparently they can still be bought at Office Depot or online.
SOURCE: Emerson DVd with Video Cassette Recorder EWR20V5
I purchased my EWR20V5 unit in December 2006. After 10 months usage it developed several problems
I've almost thrown this unit out several times, but I wasn't sure if I had to get the same unit to finalize my disks?. Is there a solution for all these problems?
David Rogerson
SOURCE: Panasonic VDR-D300 Camcorder cannot play DVD-RW (VR format) on PC
your usb cable has malfunctioned
SOURCE: disc error
Try using a lens cleaning disc (any brand). You'll find them at Wal-Mart in the electronics section, or even in your grocery store, probably near the cameras.
