Question about Haier Freezers
I have a Haier HF71CM33NW 7.1cu.ft. Chest Freezer it works great but is stuck on fast freeze . I went to replace the thermostat and sensor but I cannot get the sensor to come out.
6ya staff
SOURCE:
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
Anonymous
  • 124 Answers
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Posted on Nov 21, 2008
Anonymous
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
victorwod
Victor Nwachukwu
  • 157 Answers
SOURCE: Zanussi Electrolux Chest Freezer seems to have
change the thermostat
Posted on Feb 20, 2010
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: How much amps, volts and
all this is on label on equipment.
Posted on Feb 28, 2011
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Lost owners manual
You only require fast freeze if you are using the freezer for the first time, after a defrost, or if you add a large quantity of fresh food to an already running freezer. Most freezers require about eight hours at fast freeze. As to the temperature setting I would suggest you purchase a purpose built freezer thermometer (very cheap) and place that on top of the food. With the thermostat control set mid way (about 3 or 4) check the thermometer occasionally see what the temperature reads. It should be around -18C, if it's lower then set the thermostat lower at 2-3, if its higher set the thermostat higher at 4-5. Repeat this until the freezer temperature is correct.
Dec 26, 2013 | Haier 3.6 cu. ft. / 102 liter Chest...
The freezer freezes two hard , there are 2 switches on it are they both suppose to be on?? one is orange and one is white.
Well hello...on your freezer...the orange switch is for "fast freeze" and should not be on constantly...only when you want to freeze items really fast.If you have it on...turn it off.Also do you have the temp control set at maximum...If so...try to reduce the seting by one number.If not...leave it as is.Give the freezer about 24 hours to re stablize.That should do it...also...you will notice a reduction in your electric bill as the fast freeze switch causes the unit to draw a greater amount of electricity..MAKE SURE the orange switch is off...I hope this was helpful....PEACE...
Jan 05, 2012 | Haier 7.3 cu. ft. / 207 liter Chest...
I unplugged my chest freezer to clean it out, when I plugged it back in it won't get cold. It's in excellent condition. Never has it gave me a problem. It's approx. 5 years old. Ed V
Try turning the thermostat down to O and then back to max a few times this may free a stuck bimetallic strip. If this doesn't work and assuming you haven't damaged any components in some way then all that may be required is a new thermostat.
Nov 28, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier freezer and it wont freeze what should i do?
dear sir/madam
please make sure your freezer,s tempreture sensore is right location .if it,s alredy is in right location then reset the selectore swith to turn off and again turn possition.
hope answer the question.
thank you
Jul 03, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Any possibility you can help troubleshoot a larger upright freezer? Our freezer is 3 years old. It sounds like it is working -- I can feel cold air and hear it humming, but as of yesterday it stopped...
Assuming the thermostat is set to call for cooling (sometimes they get bumped), check the condenser coils, fan, etc for debris build up and clean as needed.
Is the freezer frost free? If so, it's possible the defrost timer is stuck in defrost. There should either be a mechanical timer or it could be electronic these days. Check for bad connections or any obvious signs of damage (burn marks)
Make sure the freezer door closes tightly
Jul 25, 2009 | Haier 3.6 cu. ft. / 102 liter Chest...
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Freezer freezes but does ever stop running
Nov 20, 2008 | Haier Freezers
Haier 5.0 cu. ft. HCM-050 not freezing
Unfortunately this sounds pretty surely like you need to get your freezer checked for leaks and re-gassed; control on refrigerants these days makes it very difficult and probably illegal to try and do this yourself, but any refrigeration repair guy should be able to do the job. slight worry is that the compressor could have seized, but this is not so often the case, sometimes a sharp whack can unjam a compressor, but get the fridge guy to look at it if he does the gas. Hope this helps :)
Mar 11, 2007 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
548 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
