Tablets & eReaders Logo
D
Doreen Cox Posted on Aug 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I plug in earphones on Android tablet
Philippe Dekyvere
Level 2:
  • Expert 30 Answers
  • Posted on Dec 23, 2018
Philippe Dekyvere
Expert
Level 2:
Answers
30
Questions
0
Helped
50118
Points
105
If you have a usb-c port, buy a usb-c to audio adapter split cable
Sound in speakers is lousy
Tablets are notorious for bad sound. I use a volume adjuster app to boost sound and use earphones.
How to get my iphone headphones to work on my digilandL 718m tablet?
Hi Amy
Be aware
There are different length's & thickness's of earphone plugs
Also the spacing on the earphone plug shaft between the black and silver connections may be out.
Take your tablet to a shop & checkout what works.
Cheers
My iPhone headphones won't work on my digilandl 718m tablet how can I get them to work on it?
Hi Amy
Be aware
Cheers
Headphone connectors YouTube
1helpful
I can barley hear my dragon 10.1 even at full volume
If you are talking about speaker volume, not earphone volume, chances are you have a defective speaker assembly unit which must be replaced.
1helpful
Having problem with the sound. Only can hear with headset... Is that how this table is set up?
It is very possible that the earphone jack is defective and causing the problem. I had a tablet that would not make any sounds through the speakers after I plugged into the earphone jack and then removed the plug. I could hear only through the earphones after that. The problem was caused by a fault in the earphone jack. I had to send the tablet back to the manufacturer where they replaced the faulty jack. But before you send the tablet back to the manufacturer make sure that the tablet isn't muted by going to "settings" then go to "sound" and see if it is turned down or muted.
Nosound from earphones onGalaxzy 4 tablot
what did you clean them with ? water?, bad move. you should only clean your electronics with acceptable electronic cleaning solutions,
or Rubbing Alcohol on a lint free wipe very lightly saturated then swing the cloth around in the air for a few second to make sure its not dripping wet, but very lightly damp. then make sure all units are off with no current flowing through. also make sure that you DO NOT turn them on straight after let them dry completely. ( when applied to items should see a streaking not an overall wetness.(if overall wet, you've used to much) drying time is based on wetness.) Use hair dryer if necessary.
Good Luck, try the dryer on the headphones. including the tablet plug in area. you might have gotten water in it.too!
1helpful
How to reset Prontotec 7 Inch HD?
Hi
Do you mean reset the Tablet? These Tablets don't have mechanical HHD they are IC's.
If you want to reset the Tablet to factory settings use a small stiff wire such as a paper clip, eye end of a sewing needle. Push it into the small hole between the earphone & HDMI sockets on the side of the Tablet. Push the reset button to reset Tablet
Cannot hear radio broadcast audio
First thing to check is your settings for sound. Go into settings and click on sound . The options are there. Make sure it's not on mute or something similar. Try changing the setting. Next is plug in your earphones in the jack. If that works then your jack is open after you take the jack out. If none of this works then a connection to your internal speaker has come loose or off.
I am not familiar with your unit. Just standard stuff on all tablets is what I am suggesting.
1helpful
Bauhn faulty audio jack
Hi have you try different headphones? If it still don't fix the problem you need to replace that socket or if your tablet got Bluetooth use this insted. Regards
2answers
Juice spilled on it and now after reboot it has a white screen. I thought the pantech element android tablet was waterproof...is it damaged?
it's only water proof when all the ports - usb - earphone are closed
"The Pantech Element is waterproof against incidental exposure to water when all ports (incl. USB and earphone ports) are tightly closed, but is NOT designed or intended for in water use. Waterproof based on IP57 rating. "
see if it's under warranty to return defective
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
