Question about Hoover Washing Machines
Hoover washing machine 1300 model SE 234-80 Broken door hinge require new one
    Top Expert:
  • Hoover Master
  • 66,470 Answers
Contact a hoover repair service,
Posted on Aug 21, 2018
Anonymous
SOURCE:
robert samples
  • 1314 Answers
SOURCE: HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Posted on Mar 23, 2008
edward hayes
  • 12 Answers
SOURCE: Need User Guide for Hoover washing machine
you can download manual from hoover.co.uk
Posted on Mar 27, 2009
marionbagget
  • 718 Answers
SOURCE: i need instructions for a hoover quattro 1300
Try checking inside the front right of the soap draw there should be a plastic tab strip with all the settings on it.
You can go to;
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=11
and enter a model number. I believe the manual will be "British"
Are you may have to contact Hoover and have them e-mail the user manual.
Posted on Apr 05, 2009
Anonymous
  • 52 Answers
SOURCE: Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 26, 2009
Anonymous
SOURCE: replacing door hine on hotpoint washing machine
Its a ***** of a design. Mine is a Hotpoint Aquarius 1200 WD62. If you cant get the backing plate then get someone to tilt the machine right back and you can put your hand under to get it out. Then take the top off the machine(3 screws at the back). Then slide your soap tray right out,(put it to one side) you will then see 4 screws (Which hold in the other tray that holds the soap tray) take these out, you will then need to remove this white plastic tray to get your hand down the machine to reach the place were the backing plate goes. Once u have taken the screws out slide the soap tray holder to the left or right (can't remember) it will then come loose. You will then need to slide it back to lift it out the way (No need to take the pipes off the back of it) you may need to push the whole drum back at the same time you are pushing back the soap holder (Be gentle but it will come out). The holder should then lift up out the way, you can now get your hand down to hold the back plate on whilst you get a helper to affix the door. Make sure backing plate is on the right way, the screws will only go in one way (Check which way b4 u put it down into place). Then go backwards on all steps to put machine back together. This sounds like a load of **** but it worked for me and took about 15 minutes. Good luck!!
Posted on May 15, 2009
I need a replacement door for my Hoover Easy Logic 1100 aa Washing machine. I beleive that the model is discontinued but my machine is in perfectly good working order. Could you advise anywhere where I...
I searched for quite some time without success and I am Pretty good at finding things.
Contact Hoover using this link:
http://service.hoover.co.uk/spares
To order Hoover Genuine Spares & Accessories please call 08443 712758
Opening hours: Mon-Fri 8.30am - 5pm.
I could not even come up with the part number for the door. I did find the following:
1. Door Seal
2. Door Glass
3. Door Handle
4. Door Hinges
No luck on finding the complete door assembly.
Another alternative... if the Yorkshire area has an appliance recycling venter you may be able to find one there or in the classified ads "for parts only" But then your faced with disposing of the "junk."
I recommend you contact Hoover using the number or Lonk above and see what they can do for you.
I wish I could have done more for you but the whole door assembly just does not seem to be readily available.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Washing Machines
How do you repace the door hing on a AAA140 Hoover
should not need to as the 2 screws holding the hinge to the frontplate of the machine goes into a threaded nut welded to the panel (a torx 30 or 40 bit is needed).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Dec 18, 2009 | Hoover Washing Machines
The machine door is hanging off the hinges xx do i need a new door or hinges
More than likely, all you need to do is replace the door hinge., you will probably have to seperate the inner door panel from the outer panel to fit new hinge.
Please rate my solution.
Thanks.
Sep 09, 2009 | Hoover Washing Machines
Hoover 1300 washing machine door wont open
Hi.
The door will not normally open if there is water left in the m.c. check pump, and make sure the belt is o/k, as some hoovers do not let you open the door if the belt has come off. Please leave feedback.
Thanks.
Nov 25, 2008 | Hoover Washing Machines
Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Jan 14, 2008 | GE S8000E
Washing Machines Logo
46 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
