SOURCE: My TV keeps switching from HDMI 1 to TV by itself
You might want to unplug the HDMI cable at the back of your TV first, then unplug the power cable of your TV for 10 seconds then plug it back in, then plug back your HDMI cable.
I hope this will resolve your issue.
SOURCE: dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
SOURCE: How do I get my PS4 to play via NEC NP310 Projector it has no HDMI input?
you need a hd projector
