I put the co2 in and pull back to fire and nothing happens just paint ball rolls out of barrel
SOURCE: paslode finish nailer wont fire
CHECK THE SPARK! IF YOU HAVE A JOBSITE RADIO YOU CAN HEAR THE SPARK ON THE AM BAND AND TELL IF THE TOOL IS FIRING!
SOURCE: bsa superten problems firing
Give BSA a call at: 01494 676740 If you're not in GB, it's an overseas call.
I know it's a dumb question (maybe), but are you sure the bolt is fully advanced and locked and the safety's off?
SOURCE: car wont roll forward or back even in neutral
I assume it's a manual transmission.
If the car will not roll backward or forward in neutral (with or without the clutch engaged) the transmission is most likely locked in two gears at the same time.
This may happen if gear selectors are excessively worn. If you are able to examine the gear selection levers external to the gearbox, ensure they are in the 'neutral' (no gear selected) position when the gear lever is in Neutral. If not in correct position, you may be able to manually reset the levers to correct neutral position and thereby unlock the gearbox.
In any case, if it's happened once, it will happen again, so get the gearbox and gear selection mechanism checked for wear or breakage.
SOURCE: Rear passenger window won't roll up after I rolled
These models are prone to corrosion of the winder cable mechanism due to water ingress from the window rubber seals being poor so, the money is on a broken winder cable. Hope this helps
Testimonial: "That makes sense from the symptoms but I wonder what is an economical solution?"
