Question about Meade Optics
I have a Polaris Meade Electronic Digital Telescope DS-60 Autostar and I need a manual for this, hope you can help!
6ya staff
SOURCE:
Anonymous
SOURCE: Meade 114EQ-DH$ Manual needed
114EQ-DH4 same as 4504. Manual on Meade website
Posted on May 15, 2008
Anonymous
  • 1027 Answers
SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Posted on May 22, 2008
Anonymous
  • 67 Answers
SOURCE: Meade DS-2000 Manual Doesn't have info. about Meade Ds-2130
ds-2000 refers to the model line of the scope. ds-2130 the 130 refers to the diameter of the objective lens in mm. I have a ds-2114. Where the objective lens is 114 mm in diameter. as far as the manual goes everything else should be the same.
Posted on Dec 08, 2008
SOURCE: Manual For Telestar By Meade
Here are all of Meade's manuals ----
http://www.meade.com/manuals/index.html
Posted on Dec 29, 2008
Anonymous
  • 73 Answers
SOURCE: vista will not work with autostar 494
I did some research on meade 506 astrofinder software
Read this...
Customer Review:
Rating: stars-1.0.gif
Summary: outdated software
The software this kit comes with is old and outdated. It is not supported by Windows XP nor Windows Vista. The latest supported version of Windows is Windows 98.
It also appears that the included software is a limited trial software. It is limited to the included 3 catalogs (star maps). The complete set of catalogs must be purchased additionally at quite some expense.
The cable connection kit couldn't be reviewed because it was missing from the package I received, but keep in mind when you order this kit, that neither Windows XP nor Windows Vista support serial ports anymore. The additional USB to serial adapter would be required.
That last line would suggest to me that if one had a USB to Serial adapter it might work? but I really do not know for sure. checking into some more stuff...
Found another article that states "It requires a PC running Windows 98SE through Windows XP. It will not run under Windows 95 or earlier, nor will it run under Windows Vista."
OK I found this site, you might be able to make some sense of it. But I did read in there that they do make USB serial adapters that will work with Vista OS.
Good Luck and happy star gazing! If you find something new out there maybe you could name it after me if you get it working. lol
Posted on Mar 07, 2009
I am looking for a insruction manual for a Meade autostar DS-2130 AT computer guide telescope
All of Meade's manuals are on this web site-- look toward the bottom of the page--
www.telescopeman.org
Jun 20, 2011 | Celestron NexStar 130SLT (31145) (306 x...
I need a manual for operating the Telestar DS-114. I want to teach my class how to use the computer driver.
All the manuals are on the Meade website here:
You can control a Meade scope using several different planetarium programs if you have the correct Meade cable.
Stellarium, and Cartes du Ciel both can control the scope. If you have a real serial port on your computer you can use the Meade cable and plug in to the bottom of the hand controller.
If your computer does not have serial ports then you must buy a USB to Serial adapter cable. Keyspan is a good brand.
Feb 11, 2011 | Meade 4.5" Telestar tonian Reflector...
Suite does not open port to DS 2080 telescope
What computer are you running? XP? Vista? Windows 7?
Also if you do not have a real serial port on the computer then you must use a USB to Serial adapter cable.
There is also new software on the Meade web site here:
http://www.meade.com/support/downloads.html
Oct 05, 2010 | Meade Autostar Suite Autostar Suite...
Set up autostar
You can get one off the Meade web site here:
Find your telescope on the above page and download a free manual.
May 01, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Meade autostar computer wont go up or down only
Could be just a bad cable. Contact Meade customer service.
http://www.meade.com/support/index.html
Oct 11, 2009 | Meade DS-2130ATS (250 x 127mm) Telescope
Where can I find instructions for the Meade 114 mm Autostar telescope
All of Meade's manuals are located here--
Jun 14, 2009 | Meade 4.5" Telestar tonian Reflector...
When i turn my LX-90 8" telescope the GPS is not working.
After you RESET the telescope-- it returns to factory default settings--
1. Calibrate Motors
2. Train Drives
3. Set Time, Date, Site, and Daylight Savings Time to NO right now in USA
4. Calibrate Sensors on Polaris
5. Do an Automatic Alignment--
Here are all of Meade's manuals on line--
Dec 30, 2008 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
Dec 21, 2008 | Meade TeleStar DS-2114ATSA Telescope
Optics Logo
201 people viewed this question
Top Meade Optics Experts
Gep Pep
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
