SOURCE: How do I enter the 5 digit code on my Becker radio?
The screen should show CODE * * * * with the "C" flashing
Use the +/- keys to set the first digit of the code onto the screen and then
press the "M" key to move to the next digit. Repeat the process until you have
all 5 digits of the code on the screen and the press and
hold the "M" key to
finally enter the code. The radio should now operate.
Testimonial: "Thanks to yhendricks1: your advice worked perfectly. Thanks. John B"
SOURCE: Security code for Becker car radio
lost radio code of MB Becker truckline CD65 BE 7045 serial no 68015713
SOURCE: i need code for becker car radio/c CD player le
the code is :-
12411
i hope this will be helpfull.
Please rates me
Goodluck............
SOURCE: I need the radio code
The radio SERIALNUMBER will be required for calculating a code On some radios, pressing Buttons 6 and 1 or 6 and 2 (together) maydisplay a Serial Number If not , then removethe radio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
SOURCE: hi , i recently accuired
61633 is the code ,as for the wiring well thats simple enough just look carefully at the wires and seperate the speaker wires from the feeds the earth will be the chassis of the radio or often the aerial wire as the as the outer sheaf is earthed .It will have two feeds one a permanant 12v memory and the other a ignition feed 12v for on and off with the ignition key
Testimonial: "Damn fast service !!"
