Question about Hoover Washing Machines
How do you get the top off a hoover special edition 1400 as the start button has gone in.
4 Suggested Answers
Anonymous
SOURCE:
hmlee390
  • 736 Answers
SOURCE: BURNING SMELL COMING FROM MY WASHING MACHINE
if it smells like rubber burning then i would suspect a belt is worn or slipping or somthing has jambed the basket from turning .. the belt is not expensive ..labor of course would be extra .. if the burning smells like insulation or a strong electrical burning smell then you may have a bad motor .. those used to be about $70 + labor .. no telling what they get for them now ...
you mention that the smell came from inside ... do you mean inside where the cloths are (the tub) or inside the cabinet (outside of where the cloths are) ...if the smell was coming from inside the washing tub .. then i would suspect something cought between the inner and outer tubs .. if the smell is not from there then the first suggestions above are good ... bras and slippers and such are good for getting cought .. check where the movable tub (with holes) meets the outer tube (no holes) .thats at the very top of the tub .. ..make sure nothing it cought there ...
Posted on Aug 05, 2009
john_cross
  • 6277 Answers
SOURCE: hi im strugling to get
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 22, 2011
Tom Smith
SOURCE: User manual needed for Hoover washer/dryer
I think you connect wires wrongly and after that it is not working in a proper way so here you need to change the wire position for working in a write way.
Washing Machine Warranty service
Posted on Aug 31, 2012
Following freeze, water is gushing underneath hoover washing machine when mains turned on.
You'll need to tilt it or remove the back or pop the top to see where the leak is coming from. Unplug it first. I had my water pump crack and leaked. It was a plastic part not related to freezing though, and it only leaked when it ran a cycle. Perhaps your leak is prior to the water pump.
Mar 10, 2018 | Hoover Washing Machines
Hoover vision hd 1400 aaa manual
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
Jun 16, 2013 | Hoover AAA140 Front Load Washer
Hoover 1400 AAA washing machine tripping house fuse
Possible that the control panel is short and so is tripping the fuse. Remove the connection to the panel and check if there is short , also remove the motor and check and this can confirm the case.
Jul 03, 2012 | Hoover Washing Machines
My Hoover Optima WMH147DF has gone nuts.
call a local repair service , we can not fix control boards that wiggle
Jan 08, 2018 | Washing Machines
Hi im strugling to get the hoover special edition se 148 8kg 1400 AAA user manual and need assistance finding it
Good luck,
John C
Feb 22, 2011 | Washing Machines
Just moved into a house in Singapore with a Hoover D6786 dryer. It starts up and spins but repeatedly stops spinning after only 5-7 minutes. Clothes will not dry. What's up? Thanks for any help.
This is normally the sign that the electric motor start/run capacitor has gone faulty: the special motor start/run capacitor, usually around 4 to 10 uF / 450v, helps the motor during the stop/start sequences which require higher torques.
Aug 05, 2010 | Hoover Dryers
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
37 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
