Electrical Supplies Logo
R
Roger Larsen Posted on Aug 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gentron Generator GG10020, hose leaking coming from silver triangular part and into the air filter. Cannot find where it connects in the air filter compartment. Spews out hot black fluid.
CJ Rock
Level 3:
  • Electrical S... Master 4,429 Answers
  • Posted on Dec 07, 2019
CJ Rock
Level 3:
Answers
4429
Questions
0
Helped
1644726
Points
15024
Https://www.absolutegenerators.com/gentron-generator-diagrams
I believe you're describing the crankcase vent tube. This typically runs from the valve cover to the intake near air filter.
A small amount of oil is normal, but your description of spewing implies fuel in the crankcase oil.
Check the oil level and viscosity. If oil level is high and thin then it likely has fuel in oil. This oil fuel mix is what is being vented.
The typical cause for fuel in oil is a stuck carburetor float, stuck carb needle valve, or debris in carb needle valve.
Remove carburetor bowl and clean. Check float and needle operation. Reassemble carb then drain and fill with oil.
sherlywang
Level 3:
Master:
  • Electrical S... Master 428 Answers
sherlywang
Level 3:
Master:
Answers
428
Questions
0
Helped
198505
Points
1063
Starlight power diesel generator set website for your reference:https://starlightgenerator.en.made-in-china.com
1 Related Answer
mdc674lpn
mdc674lpn
  • 47 Answers
  • Posted on Jun 13, 2010
SOURCE: antifreeze is leaking from black hose but closer to silver clamp
that is a coolant hose that leads to your heater core. previous instructions will help you solve problem localauto parts store will have the hose you need either 3/4 inch or 5/8 inch hose.
The start toggle switch has gone bad on my Gentron generator gg10020 Where can I get a new switch
We hold the switch you need :)
https://www.generatorguru.com/gg10020-gg10020c-1/?sort=featured
Gentron generator model GG10020 trouble shooting ignition systems
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/Regards,
The Generator Guru Team
2answers
Generator starts up ok. Hooked electric cord to house outlet and other end to generator but not electricity came on.
Check the position of on/off switches, and circuit breakers that may be interrupting the flow of current.
Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Gentron gg10020 carburetor
Float probably stuck. Remove and rebuild the carb.
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
