SOURCE: 2001 ford focus anti theft
yes its possible to disable the alarm immobiliser ,remove the ECU unit .then solder in a 12v supply from the on side of ignition,find a suitable connection in the wiring harness feed and solder to a switching transistor on the side of unit with a heat sink to the base connection of a transistor that controls the feed to another three transistors ,starter motor earth for relay,fuel pump earth relay,and ignition ,no relay and away you go location of transistors iam not saying as i dont wont the car theives reading it ,but its as easy as falling off a log when you know the colour of the wires, pin numbers and a magnifying glass soldering iron .took me hours to follow the the connections in the fuse box separating the two halves to follow circuit,tracing wires back to ECU then following printed circuit but i have done it .SO DEALERS EAT YOUR HEART OUT ANOTHER FOOD WITHOUT WORKING FOR IT JOB LOST .going to try it out on a dammed renault when i get time.Also sell the details over the internet ???? no i dont think so iam just glad i have pissed off the local dealers that wanted 200€
SOURCE: anti theft system
The chip is in the key. Either the key has lost it's program or the transceiver is not recognising the key. Try another key if you have one.
SOURCE: 2001 ford taurus wont start and anti-theft light is blinking
Either you may be using a key that you had copied from the original or your chip went bad in your original key. Most of cars now a days have the key censor in the key so if it is the incorrect key it will not start your car or if it does not read that chip it will not start
SOURCE: 2001 ford winstar van v6 eng wont start do to anti theft system is on how i turn it off
2001 widnstar won't do anything. Won't start, can't shift
