The specifications for the Kenmore 110.24922200 indicates that this is a super capacity plus washer. That means it has a 3.2 cu. ft. capacity. See https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0305205.pdf . All of the documents for the washer are available here: https://www.searspartsdirect.com/partsdirect/user-manuals/11024922200-kenmore-parts-manual . The capacity information for the Series 90 washers is available from ShopYourWay: https://www.shopyourway.com/questions/1043967 .
I hope this helps.
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
SOURCE: kenmore 70 series washer 110 22702100
3.2 cu Ft
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
