SOURCE: Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
SOURCE: Replacement Sun shade
Replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Contact Us
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
SOURCE: Dell 5100 Started printing wrong shade of cyan.
do a gradudation on machine it will reset all ya colours up properley
Copier tech
SOURCE: broken sun roof window shade
i had this same problem i think u have to take it in to get replaced. i try to get to the stupid thing but it was a ***** to take everything apart. around the framin of the moonroof. and u still need to get the retactable thingy. have it replaced. unless u have more patience.. but beware once u start to take ur car apart.. the top roof cover might become loose if u dont put it back the way u had it..
SOURCE: My NEC mt1075 projector is projecting a shade of blue all over.
If you're using component video (red/green/blue rca cables) one of the colors may be disconnected, or the wires may be swapped into the wrong color input. If you are using a 15 pin VGA connector, one of the pins may not be getting good contact at the source or at the projector. Or if the VGA cable is split into 5-wire to make a long cable run, one of the five wires may be disconnected. Any of these problems will cause a global color shift while not affecting the color of the projector's on screen menus.
