Question about Mackie Music
I need diagram profx16 mackie for service .tank.
Do i need a converter to use the mackie 15-a powered speakers outside the usa?
Possibly> It will depend on exactly where you're traveling to. Contact Mackie customer service to see if the transformer is tap-able to different voltages. Contact Support Mackie
May 17, 2017 | Mackie Music
Hi my mackie thumps 100 watt aren't delivering a decent volume ,,I,m using mackie mixer please help
Is this a new problem? In other words, was it working correctly at some point?
You ned to isolate the problem. Plug a different source into the speakers and plug the mixer into a different amp/speaker. See which part isn't working correctly.. Either way, it's likely you need to take the part that's not working to the shop. You can contact Mackie to find the nearest service center. Service Locator Mackie
Nov 28, 2016 | Mackie Music
I have a Mackie 406M Powered Mixer. can't get sound out of it anymore. all the input level set lights stays on. any suggestions
That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
May 18, 2016 | Mackie Music
Hi there, my relatively new Mackie Thump wont power up despite being plugged in / on etc. When I do with it on all i hear is a very low pop sound every 5 to 10 seconds or so
Your best bet is to contact Mackie Tech Support. Here is a link to their Suppot page. Mackie Tech Support
it's likely it needs to go to a repair shop. Here is a link to their service center finder. Mackie Service Center Locater
Feb 05, 2015 | Mackie TH-15A Active DJ Powered THUMP...
Problem with the Mackie SRM 450 v2
It would be very unusual if the blue LED is burned out. They should last a million years. I suspect the power supply has a problem.
Apr 03, 2017 | Mackie Srm450v2 Srm450 Srm 450 V2 Active...
I own a Mackie CFX20. It isn't the MKII. The effects are very weak, and they buzz a little when you try to use them. How can I fix them, and is a service manual available?
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
http://www.mackie.com/support/downloads/discontinued.html
http://www.mackie.com/pdf/cfx_om.pdf
http://www.mackie.com/pdf/cfxseries_ss.pdf
http://www.mackie.com/pdf/cfxseries_hu.pdf
http://www.mackie.com/de/pdf/CFXSeries_OM_German.pdf
Feb 21, 2012 | Music
Where I find power transformer of mackie 1604
You should be able to get this directly from Mackie service. Please see the link below for the contact information. Please note that the exact model number adn serial number will be required to insure that the correct transformer is obtained. There are a few variants of the 1604,
Dan
Link: http://www.mackie.com/support/service/index.html
Jul 19, 2011 | Mackie 1604 VLZ 3 16 channel Analog Mixer
Heiio,sir my mackie hd1531 is power supply is dammege plese send this service diagram. i hope you help thanks
You can try this site:
http://elektrotanya.com/mackie_sr1530_active_speaker.rar/download.html
This MAY be very close to your system... there are several parts to the schematic in this compressed file...
OFTEN companies do NOT re-engineer things so one has to use intution as to what the model number thisng might be listed...
You often find modules are identical between units even though the model is labelled differentely.
Nov 15, 2010 | Mackie HD1531 3-Way 15" HD Powered PA...
Music Logo
50 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
