Televison & Video Logo
T
Terri Ellis Posted on Aug 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I do a factory reset ? On Element tv? - Element Televison & Video
Sangeeta
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 14, 2021
Sangeeta
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
3567
Points
22
Yes, of course its confusing to reset elements TV. I also found many issues to reset it and fix the common issues,
Even I lost my remote which added a lot of burden to my existing issues with the TV.
I found this guide https://sensemother.com/how-to-reset-element-tv-without-remote/
It did helped me a lot to fix the issues
Mark Cheong
Level 3:
Master:
  • Element Master 791 Answers
  • Posted on Aug 28, 2018
Mark Cheong
Element Master
Level 3:
Master:
Answers
791
Questions
0
Helped
475622
Points
2475
First, I'm not an Element representative.
* check your warrant. Call for support.
* support; https://www.elementelectronics.com/support/
*** Following is for information only.***
* Google's answer; Hold down the menu button on the top or side of your TV for at least 10-15 seconds. An on screen menu will appear asking you to enter the time, date and location settings. Follow the onscreen instrucitons, and once completed your TV will reset to factory settings.
* You Tube; https://www.youtube.com/watch?v=I1-3LLAhMJw
* another vid; https://www.youtube.com/watch?v=xLwUIZjeHpA
Aloha, ukeboy57
1helpful
2answers
I have an Element 32 inch tv and the volume goes down by itself. I've tried everything to fix it without taking the back off. Please help.
Disconnect the front button board from mother board. Problem solved, of course then you will have to use a remote for everything.
My element tv will not find any channels
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Hi!!! I have a 32" inch element tv and my kids turned on that awful background talking when closed captions is on I have to have it on I am partially deaf ...please please help its driving me crazy
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
HI, I "inherited" an Element TV, Model FLX-2210 and many of the shows are blocked. Any idea how to unblock them? My sincere thanks.
Do a factory reset. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Does my element flat screen TV have a reset button?
There is no such external button. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Rest tv element 36 inc
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Element tv eleft422
Without its remote control, you can't do a system reset to this set.
Try a Hard Reset to this set, and then check.
https://electronicshelponline.blogspot.com/
If a hard reset do not help, you should buy its original remote control from its authorized service center.
I have an Element LCD 32" tv and my kids were
Check this link. http://electronicshelponline.blogspot.com/ . The reset procedure is given in detail. Type in the brand name to your TV to its search box at the top right, and search.
Top Element Televison & Video Experts
matt martin
matt martin
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
