SOURCE: Won't start.
Hi raw 28:
ther gas that was in the carb probably evaporated. you might tryt a little spray starter fluid in the spark plug hole or in the air intake of the carb, This might just get it running long enough to draw gas into the carb and get it self sustaining,
Good luck Loringh
SOURCE: McCulloch Generator model FG6000mk 11hp run good
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
SOURCE: I have a generator with
if this engine does have such a thing which i doubt as its normally only found on diesels but if its fitted it will be on the rocker cover as it will be a lever that holds the exhaust valve open ,so it will be at the top of the engine .This decompressor is normally only on engines with no electric starter motor and a starting handle ,you open the decompressor -swing engine to get a bit of speed then open the decompressor and if you have prayed to the right god it will start without sending one to ones maker with a heat attack.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
