Have checked fuse, socket, and wire not loose
SOURCE: TV GOES ON STANDBY WHEN IS TURNED ON
tv might be in display mode, check with owners manual on how to diable this mode.
SOURCE: my tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
SOURCE: TV wont turn on. Standby light blinking 7 times in sequence.
It will most likely need the power on switch replaced its very common
SOURCE: Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
