I can't adjust any other settings. I would like to do factory reset but can't get to general settings. I tried remote control and buttons on TV itself.
SOURCE: How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings
via the MAIN MENU screen when you press both CH UP (8) and
DOWN (9) on the TV set.
• Some features of your TV Set will not be accessible without the Remote
Control. If you lost your Remote Control, contact a Sharp Authorized
Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
SOURCE: i have a dvdvr375 that needs factory reset. How?
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
SOURCE: remote wont work and can't acess menu with tv
Turn your Sony Bravia on by pushing either
the power button on the front of the TV or the power button on the
remote control, which is located in the upper right corner of the
remote.
Read more: How to Reset a Sony Bravia TV ' eHow.com http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html#ixzz1Cn2noiTF
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
Turn it on while holding the menu button on the side at the same time and hold it
