Question about Dewalt Drills
How do you put a dewalt dc920 drill back in the case
Anonymous
SOURCE:
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Posted on Mar 05, 2008
stug_57u
Stuart
  • 99 Answers
SOURCE: dewalt 18volt drill xrp dc988 in pieces
If you are in the U.K. go here fore tech help and service dealer locator etc https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB
If you are elsewhere go to www.dewalt.com and you can navigate to other countries etc from there.
Posted on Oct 26, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: looking for repair manual for Dewalt DW87 cordless drill
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. From there you should be able to download a schematic and some of the parts are component parts and don't have a lot of replacement items. It sounds like you broke the clutch or gearcase and both are components.
Posted on Apr 01, 2009
Anonymous
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: how to put my drill back together
I would recommend going to Dewaltservicenet.com and typing in your model number to get a parts explosion. If you get that and still have problems let me know along with the model number and I will try and help
Posted on Aug 05, 2009
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Apr 04, 2011 | Dewalt 18 Volt Compact Drill Kit
How do you get the dewalt dc 390 cordless saw back in the case. darndest puzzle I ever saw
Take the batt. off and drill bit out. Also make sure you are putting the drill away on the correct side of the case.
Apr 17, 2010 | Dewalt Saws
**** no...deceptive downloads asked for DC930KA DeWalt Users Manual and got **** advertisements about hazmat ******* gear
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/652900-00,DC920.pdf
link to manual
If you have trouble just go to http://www.dewaltservicenet.com and type in your model number. parts lists are available as well.
Feb 24, 2010 | Dewalt DC930KA Heavy Duty Xrp 14.4V...
How can I take a part my dewalt 12 volt drill
Hi there, Remove the battery and sometimes the screws on the drill casing are a torx instead of phillips so you will need a set of torx screwdrivers. Once you have removed the screws from the casing be very carefull when pulling the two casings apart, try to leave the chuck, motor and switch assembly in one half of the casing as it makes it much easier when trying to put it back together.
Jan 01, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
Tools are junk moved on to ridgid
Wait until you have problems with that Ridgid. Parts very hard to find. Ridgid Tools have great threading equipment like the 700 and 300, but their cordless tools are not easy to get help with. DeWalt has a very good warranty program. The dc920's have had a lot of clutch problems and switch recalls, though. Their saws (mitre, circular, etc.) Best in the business. Good luck, friend. Lemme know if you need anything. Please rate me.
Jun 12, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Hamer drill xrp
if the battery are less than a yr old should be a warranty
if drill DC920 or DC925 they are on recall for switch. may be co'z the battery to die. have them check at ur nearest service center.
Jul 13, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
18V xrp Drill Help
The problem could be the brushes and if so it is be quit easy to replace them by pulling the drill apart and slipping the old ones out of there sleeves on the armature and slipping the new ones back in there place . you can buy these brushes at any good tool shop . all you will need is the model number of the drill which you can locate on the side case of your drill . hope this helps.
Nov 04, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
253 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
