Question about Symbol Computers & Internet
What does the triangle symbol mean only screen, upper left side?
6ya staff
SOURCE:
mirran
Mirko Blas
  • 515 Answers
SOURCE: What does the triangle symbol with small objects in it mean?
It´s the descaling indicator, you need to descale the machine.
Posted on Jul 15, 2008
Anonymous
  • 81 Answers
SOURCE: My IBM ThinkPad showing a black screen with a
That usually means there is a system password that needs to be entered. If you do not know it, you must remove the CMOS battery from the laptop and reset it.
Posted on Jun 30, 2009
Anonymous
  • 6 Answers
SOURCE: triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Posted on Jul 24, 2009
Anonymous
  • 11 Answers
SOURCE: light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
Posted on Aug 17, 2009
Anonymous
  • 491 Answers
SOURCE: symbol with exclamation mark in a triangle keeps
How often does it appear?
Is it after the TV has been on for at least 10 mins?
It could be overheating.
Add a fan to get air flow into the set through a vent in the back....and see if that helps to keep the light off.
If this cures it....the internal cooling fan may have stopped.
Posted on Sep 06, 2009
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Mar 27, 2013 | Dell 2230d Laser Printer
What does the H symbol on the top upper left corner of the phone screen mean? How come it keeps switching between an H and a 3G symbol?
probably the state of the internet connection H could be HSDPA and 3G obvoiusly 3G. Which phone?
Nov 25, 2010 | Cell Phones
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
My IBM ThinkPad showing a black screen with a small computer symbol in the upper left hand corner with a lock symbol next to it ??? computer unreactive.
Jun 30, 2009 | IBM ThinkPad R31 2656 Notebook
I have this symbol on my screen and i dont know what it means
it means your blue tooth is activated, or you accidentally turned on the blue tooth search, so its looking for a device to connect to
Apr 03, 2009 | Verizon Communications enV2 Cellular Phone
Jul 09, 2008 | Schaerer Opal Espresso Machine
Computers & Internet Logo
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
