I'm not sure if all control layouts are the same or similar in Mercedes but I did find something that may be of help -
Mercedes Speedometer MPH to KPH
SOURCE: Watch DVD on Comand Aps Mercedes R320 CDI
Rui,
Not sure about the European version, but the American factory version will not play video DVD's while the vehicle is in motion, (Drivers area) due to laws against this. Also...just to cover the non-factory installs, most aftermarket indash DVD players have a safety switch which prevents the driver from playing DVD movies while driving the vehicle. The vehicle must be in park for the DVD player to play a movie.
Hope this helped.
JD
SOURCE: Both speedometer & tachometer not working, both reading wrong.
There was a recent class action law suit settled with GM for this exact problem. You can google gm speedometer lawsuit and get lots of information. Unforutunately for most people I think the warranty was limited to 7 years and 70,000 miles. Which isn't a lot of miles for most people.
If you car isn't covered by the warranty there is a way to "reset" the speedometer.
You can turn the ignition slowly like you are going to start the engine. There is a very small "dead" space where you will see your guage lights go off.
What you want to do is cycle the ignition switch from off to that dead space. Each time you do it your stuck speedometer will move towards zero about 10 mph. So if its stuck on 40 you will have to cycle it at least 4 times.
At first you will probably actually hit the ignition and the engine will try to start.....just release it and try it again.
I know this because I have a 04 avalanche with 80,0000 miles and it has this problem about twice a month.
SOURCE: how do I change my kilomter readings to miles
Push and hold the reset button, this should give you the option the change the settings.
SOURCE: 2005 Jimmy 4X4, 4.3L, P300 multiple misfire. Have
Try some injector cleaner in the fuel--there might be some water in the fuel also. Check the air cleaner.
