you have wi-fi calls on... just turn it off it will work that happened to me haha.. if you need to make a call via wifi just turn it on and then you can make the call
1. From home screen tap the phone button
Then tap your number keypad button.
2. Press and hold the 1 key.
and you should now be in your Voicemail center..
The other option providing your phone has notified
You that you have a msg is to tap on that notification
Icon. This should also take you right to your Voicemail.
Hopefully one of these two options will work for you.
Otherwise, I'D suggest that you contact your service provider.
Have a wonderful day!
Facebook gives you options when it comes to displaying your birthday. You can elect to share only the month and day you were born, or also include the year. When your birthday rolls around, it shows up in the top right corner of your friends' homepages. While you cannot disable the alerts of your friends, you can control whether or not your friends are notified of your birthday. Make your birthday only visible to yourself to stop friends from getting an alert.
Click on the "Account" icon in the top right corner of any Facebook screen. Select "Privacy Settings" from the list that appears. Click on the blue "Customize Settings" link at the bottom of the "Sharing on Facebook" section. Scroll down to the "Birthday" line in the "Things I Share" section. Click on the gray icon next to "Birthday" that displays the current privacy setting by default, it is set to "Everyone." Choose "Customize" from the drop-down menu. Click on the downward arrow in the "Make This Visible to These People" line to bring up a menu. Select "Only Me" and then "Save Setting."
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a notification with a voicemail message icon appears at the top of your screen. • At the voicemail notification, select Call to call your voicemail number and follow the system prompts to retrieve the message. Select Ignore to clear the notification without checking messages. The notification icon remains on top of the screen until you listen to the message • When only the voicemail message icon appears on top of the screen, select Voicemailand follow the system prompts to retrieve the message.
