SOURCE: reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
SOURCE: I need a hunter remote control unit part
This particular Hunter remote control unit has been known to have interference issues for some time now. It is very suceptible to picking up other transmissions, such as those from TV remotes, etc.
If you're having intermittent operation of the fan and/or light, you can try setting different codes for both the receiver and the remote.
That being said, the best source for a replacement unit is directly from Hunter, since you might also still be under warranty you might get it replaced for free, if you remembered to fill out and mail the warranty card!
Of course, if you just want to replace a lost or broken remote, give them a call and order one (or two and have a spare!).
To speak with a live Technical Support Representative call: 1-888-830-1326 (United States) 1-866-268-1936 (Canada)
Hope you find this Very Helpful and best regards!
SOURCE: Have hunter ceiling fan without a visual switch on
http://www.hunterfan.com/doc_search_results.aspx?search=28870
SOURCE: Hunter Fan Remote Control Part No. 85095-01:
My Hunter Remote does not have a Reverse button and can't find the manual
SOURCE: I have a Hunter 27185
Look on the botton of fan, their should be a switch to reverse Fan ,it should switch up or down.
