My x360 has 3 red rings and power supply light is yellow what is the cause
At the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Attractive article, and the website give the impression pleasant on all sides as well, I feel very excited and satisfying for your article. Your quality is so good that’s why you must admire for this. Tanks and all the best.http://www.360xboxrepairguide.com/fix-xb... 3 red lights yellow power supply
Thanks for this interesting post. Only just found this site and will be sure to bookmark it as all the posts I have read on it so far have been of real quality and value. I feel very excited and satisfying for your article.http://www.360xboxrepairguide.com/fix-xb... 3 red lights yellow power supply
hey it gives orange light when i unhook it and only plug it into the xbox 360 so does it mean power supply is bad
