SOURCE: linkage hook up for a briggs and stratton engine
wow, i have not ran into this problem yet. I am not getting any results for that engine in my usual locations, which have great diagrams. here is a link to the only diagram i can get a hold of. hope this works.
http://www.m-and-d.com/pdfs/briggs/135200-ms2810-0802.pdf
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
SOURCE: Need a wiring diagram for a Lincoln Welder
try this page http://content.lincolnelectric.com/pdfs/products/navigator/parts/P72.PDF
if ifs not what you looking for heres the service number for Lincoln
1-216-481-8100
SOURCE: Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
