SOURCE: casio ctk 496 keyboard
Unplugging and taking batteries out for 15 minutes should reset it back to factory.
SOURCE: im looking for a manual for the casio ctk 601
http://www.usersmanualguide.com/manuals/casio/CTK-601_CTK-611.pdf
here u can download manual...
SOURCE: Casio CTK 2000- won't work with adapter
If you have a volt/ohm meter try checking to plug that goes into the keyboard for voltage on the DC setting. If there is none, you will have to replace the adapter. Be sure to plug the adapter into the wall when you check it or you will get no reading. If that is not the problem, then it is probably the receptacle for the DC end of the power supply. What happens is that if they get bumped the solder connector on the circuit board breaks. If you do not feel comfortable fixing this yourself, you will have to find someone who is capable. Hope this helps.
SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
