Question about Kyocera Office Equipment & Supplies
Hi! Quick question - for fax confirmation receipts on Kyocera Taskalfa 6501i, does it only show the first page of what was faxed? I faxed 2 pages but when the receipt came out, it only showed a scanned photo of the first page but it did say that the number of pages was 002. Should I be worried that my fax didn’t go through? Is this the same with how other fax machines print confirmation receipts? Thanks!!
    Master:
  • 791 Answers
First, I'm not a Kyocera Representative.
* Check and call for support.
*** Following ins for information only.***
* Requires set up (for this function); https://www.youtube.com/watch?v=kKS1RvpNyfs
* Official set up; https://www.youtube.com/watch?v=DfqPE3SX7iE
* Print reports;https://www.youtube.com/watch?v=rTlBXc0UObM
* Contact your IT support or your local vendor for advice.
Aloha, ukeboy57
Posted on Sep 06, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Confirmation pages
press function
press dataregistration
press set
use scroller up and down to select the function that you want to do, there's a lot of function, like user setting, report setting vvvvv.
select user settings, then scroll up or down
select activitiy report, then set it auto print off
will help you, play around with it.
Posted on Dec 14, 2007
Anonymous
  • 589 Answers
SOURCE: printing confirmation page after completed fax
If you have the operators manual (it may be in the back compartment of the machine), look in the index for "fax parameters", then "fax reports".
Posted on Jan 10, 2008
Anonymous
SOURCE: Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Posted on Sep 04, 2008
Anonymous
  • 4 Answers
SOURCE: Need printed confirmation fax receipts
I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
Posted on Apr 26, 2009
Anonymous
  • 26 Answers
SOURCE: How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Posted on Feb 19, 2010
I need firmware
Most of the downloads are available from the official product support page here:
http://usa.kyoceradocumentsolutions.com/americas/jsp/Kyocera/productdetails.jsp?pid=19352
Dec 21, 2014 | Kyocera Taskalfa 250ci Color Copier...
How do i change the fax confirmations to come out of the side tray?
There should be a setting menu in "system settings" : Common settings , Paper tray settings.
Aug 14, 2014 | Kyocera Taskalfa 250ci Color Copier...
Kyocera 4500ci showing error 6600
Broken fuser heater wire
Fuser unit 1. Check that no paper jam is present.
2. Confirm that the wiring connector is
firmly connected and, if necessary,
connect the connector all the way in.
Fuser unit and Engine PWB (YC26)
3. If the wiring is disconnected, shorted or
grounded, replace the wiring.
4. Replace the Fuser unit and execute
U167 counter clear (see page 1-3-90).
(Deteriorated sensitivity due to the toner
adhered to the center thermistor.)
replace the fuser
repls
May 02, 2014 | Kyocera TASKalfa 180 Copier
I need set up instructions for TASKalfa 552ci
http://usa.kyoceramita.com/americas/jsp/Kyocera/productdetails.jsp?pid=21184
go down to "TASKalfa 552ci Resources Finder"
choose Technical Resources
and Manuals
choose which one you want.
Apr 11, 2011 | Kyocera Office Equipment & Supplies
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
How do i get a report of the fax i sent?
Follow the steps to setup the Fax sent confirmation report.
  4. Press OK .
Other confirmation reports in the same menu are :
Hope this is helpful
Thank you for contacting FixYa.
*Rating and comments invited on this solution
Nov 11, 2010 | HP OfficeJet J4580 All-In-One Laser...
Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
If it says zero pages sent, chances are the fax failed.
Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
How do i get a confirmation of a fax sent over a month ago?
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to
print automatically also.
1. Press Report/Help.
2. Choose the report you want by using !".
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed. The available reports are shown below:
Report name Content
Multi-Communication This report prints automatically if you have faxed documents to
more than one location by using Broadcasting.
Power Fail Report If you have a scheduled job (such as, delayed fax and send poll)
and there is a power failure, this report is printed automatically
when power is restored.
Report name Content
Help List This report covers the machine’s basic functions and commands.
It can also be used as a quick reference guide.
Sent Journal
Received Journal
These reports show information concerning the transmission and
reception activities. They can be printed on command. Or if the
machine is set to do so, they will automatically print after every
40 transmissions or receptions. For more information, see Fax
Log under the “BASIC FAX menu” on page 13
Phonebook This report shows all of the numbers currently stored in the fax
machine’s memory as One-Touch Dial and Speed Dial.
Sending Confirm This report shows the fax number, the number of pages, elapsed
time of the operation, the communication mode, and the
communication results. To set up your machine to automatically
print, see Sending Confirm under the “BASIC FAX menu” on
page 13
Aug 25, 2009 | HP 1040 Plain Paper Inkjet Fax
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Open Questions:
151 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
