Im making sweet mixed picjles it calls for whole allspice in the last step with winager and celery seed and whole all sice bring to boil add veg so my question is instead of whole all spice can 7 use pickling spice?
Cloves are more similar to allspice than pickling spice, if you have some.
Yes you could substitute pickling spice. The flavor will be different than simply allspice. Pickling spice is a mixture of many spices, including Allspice. The mixture usually contains mustard seeds, whole coriander seeds, bay leaves and red pepper flakes. You may prefer the Pickling Spice mixture to just Allspice, but if the recipe is listing the other ingredients that are in the pickling spice leave them out if you sub Pickling spice
SOURCE: Car Heater smells strange
from he Popular Mechanics site if the smell in your car is like maple syrup:
(1) SMELLS LIKE:
MAPLE SYRUP
WHEN: After the engine has warmed or possibly even after it's shut off for a few minutes.
THE CULPRIT: Coolant containing sweet-smelling (but toxic)
ethylene glycol is leaking from somewhere. It could be coming from a
radiator or heater hose, a failed intake manifold gasket or cylinder
head. It might be coming from a leaky radiator cap or the radiator
itself, especially if you smell it outside the car. A strong odor inside the passenger compartment probably means a bad heater core.
SOURCE: mix cycle does not mix add ins evenly or thoroughly
Check the belt on the motor. It could be lose or has fallen off. Also check the motor to see that it turns in a kneading cycle and check to see if you can spin the paddle freely by hand. Hank
