Boating Logo
B
Bob Tutush Posted on Sep 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the torque specs for the lower housing and water pump for a 2010 DF 140 HP 4 stroke Suzuki outboard
Richard Doherty
Level 2:
Habit-Forming:
New Friend:
  • Expert 53 Answers
  • Posted on Mar 10, 2019
Richard Doherty
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
53
Questions
0
Helped
19498
Points
120
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on May 01, 2009
SOURCE: suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Anonymous
  • 53 Answers
  • Posted on Nov 01, 2009
SOURCE: 2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Anonymous
  • 4 Answers
  • Posted on Mar 13, 2010
SOURCE: about 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
merc racing
  • 36 Answers
  • Posted on Oct 12, 2010
SOURCE: water pump impeller change
There is another bolt up under the zinc plate on the cavitation plate.
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Aug 28, 2012
SOURCE: I need to know the correct torque specs for the 4 bolts that hold the a/c compressor on my 2003 Suzuki Aerio. In order to replace the water pump it was necessary to remove the compressor. The book sup
The ac compressor bracket bolts are to be torqued to 40 ft lbs, as far as the compressor itself you can just hand tighten bolts, there is no specs for compressor bolts just bracket, the bolts are just snug.
WHAT DO YOU TORQUE A HEAD BOLT ON A 75HP SUZUKI BOAT MOTOR
1985 DT75 torque settings
Suzuki Outboard Forum https://www.suzukioutboardforum.com > forum > 589...
Apr 28, 2017 · 3 posts · 2 authors
1985 DT75 torque settings ... I've found out the torque pattern for the head is on the head but what do you torque the head bolts down to? only ...
torque specs? - Suzuki Outboard Forum
May 31, 2012
DT30C tech questions - Suzuki Outboard Forum
Jan 17, 2013
torque specs - Suzuki Outboard Forum
Jan 23, 2017
DT-55 Water in middle and bottom cylinder?
Aug 17, 2014
More results from www.suzukioutboardforum.com
I have a 2013 50hp 4stroke mercury outboard engine what is the rod cap tourqe specs to
Product Knowledge Handbook - Mercury Marine
www.mercurymarine.com > pdf > Mercury-Outboards
PDF
Specifications, features, and options are subject to change without notice. ... Connecting Rod: Linkage that connects the crank to the piston in an engine or ... crankshaft main bearing cap is secured by four bolts, rather than the standard two, for ... Found on all Mercury Marine 4-stroke ... At top speed, Mercury 50hp Four.
mercury torque specs - The Hull Truth - Boating and Fishing ...
www.thehulltruth.com > ... > The Boating Forum
Nov. 3, 2017 - The Boating Forum - mercury torque specs - im looking for mercury powerhead torque ... Proportional Serif, Monospace Serif, Casual, Script, Small Caps ... sorry for the novice question, but is this correct for marine engines? if so, ... 4-16 - titled POWERHEAD Crankshaft, Pistons and Connecting Rods (4 Cyl.) ... Missing: 2013 ‎cap
40/50/60 FourStroke - Brunswick Marine in EMEA Download ...
download.brunswick-marine.com > outboard > 4-stroke
PDF information. The description and specifications contained herein were in effect ... Name of engine manufacturer: Mercury Marine Technology Suzhou Co., Ltd. Address: ... 4 stroke. Identification of Engines Covered by This Declaration of. Conformity. Name of ... in loosening or disengagement of the steering link rod. This can.
torque specifications for 1983 50 hp mercury outboard for ...
forums.iboats.com > ... > Mercury & Mariner Outboards
Jul. 17, 2013 - I think those bolts are 5/16 and for clean dry threads 20 ft-lbs is roughly the rating. That's for a grade 5 (3 marks on the head) but marine engines ...
2answers
2010 150 Evinrude E-Tech. Motor was running great then just shut off. Will not start again.Could it be it needes to be reset, all 4 lights at tach light up showing good.
first bit of advice
do not use e-mix fuels in outboard engines
WHY
because ethanol separates from the fuel if not used continuously so letting it stand between outings is not good
secondly ethanol is hygroscopic which means that it absorbs moisture from the air that is going in via the tank vent and that results in corroded aluminium parts and rusted fuel tanks and outboards operate in a very moisture laden environment
now for the problem
being a late model engine , it should be a 4 stroke and like any 4 stroke engine , check the timing belt/chain, crank/cam position sensors , ignition module
it is important to check all harness connections as salt water rapidly causes corrosion in electrical connections and components
have the service agent do a scan for fault codes remember this
Suzuki out board 2 stroke motors were used in the early suzuki 4x4 cars and modern 4 stroke engines are simply car engines on end
Changed fuel water filter on a 4 stroke 140 Suzuki outboard . Took fuel rail off nothing is plugged. Motor starts but now rpm is high and surging ?
You need to get someone to hook up a diagnostic computer to the motor and check for codes. Make sure you did not leave any sensors unplugged as it will go into default mode.
I have a 140 Suzuki 4 stroke and a small oil leak.. where are the coolant lines in the engine please
go google and type in--- workshop manual for suzuki 140 hp 4 stroke outboard and there are manuals that are available on different site
the manuals will show where the lines are
one site --servicemanualspro.info--- has a pdf down load link
Dec 02, 2015 • Boating
I need to know the correct torque specs for the 4 bolts that hold the a/c compressor on my 2003 Suzuki Aerio. In order to replace the water pump it was necessary to remove the compressor. The book supplied...
1helpful
Suzuki 4hp two stroke impellar
Mar 22, 2009 • Boating
Top Suzuki Boating Experts
jws1013
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Suzuki Boating Expert? Answer questions, earn points and help others
