SOURCE: Trying to connect Surround sound system with 3 Other Components!?
What you have to do is to connected the Direct TV receiver and the Panasonic VCR directly to the TV set. This way when you go to the input on the TV set that this equipment is hooked to, the sound then comes out of the TV set and goes into the surround system through the cable you have coming out of the TV set marked TV out to TV audio input to the surround sound. This surround sound only has a line output, a tape output, and an aux. input. You have only one input to this surround sound unit. You should have at least two separate video and audio inputs on the TV set to use for your other equipment, and to use the other equipment through the surround sound, you simply leave the setting on the surround sound on the TV mode and and switch the different inputs on the TV set. Good Luck
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
SOURCE: power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
