Model number LCDTV32E62 I am trying to change the source from HDMI to TV as I'm using a Freeview aerial, but it will not change from HDMI o any other source
SOURCE: Sony 40V3000 - Ghosting whilst viewing via SCART (Freeview is visable through picture)
have you tried plugging your sky box into another scart socket on your tv set
SOURCE: Nintendo 64 - sound not working on new TV
Because the 64 is somewhat old I would suggest getting an aerial splitter because the system may not be able to function properly with out it. Try it and see how it turns out. Or, if you don't mind, you could play that game on the computer if you have one. Download Project64 from:
www.pj64-emu.com/
SOURCE: I want to add a DVD recorder into my TV set up
If I'm right On the DVD recorder there should be an aerial input and an output. Connect external aerial to the output then run a second from the output to the TV. Then use the HDMI to connect the DVD. This will then give you the option of recording one channel on the DVD whilst watching another thru the receiver thats built into the TV. You will then get the best poss picture when viewing DVD
SOURCE: How do i tune freeview on my samsung ps42c7hd tv?
when you press DTV, press menu,setup,tuning and follow the on screen instructions.
SOURCE: I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
