SOURCE: Oscillation stopped working!
yes I had the same problem. took apart the motor and one of the plastic gears was missing a couple teeth. Now where do you buy a replacement gear or motor?
SOURCE: my timer clock moves properly until it triggers
The clock is either hung up on the tripper or the motor is too weak to trip the off side.
My experience with them is that the motor is weak and will need to be replaced.
It is usually easier and more cost effective to replace the whole unit...
heatman101
SOURCE: Automatic sprinklers (Intermatic timer) do not
If manual override works, and dial rotates on time each 24-hours, then worn trippers are suspect.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: How do I get my turbo oscillating sprinkler to oscillate?
tighten up the knob on the lever arm on the side
